ZitatWhat is the optimal revs? (for an 1.4 , 1.6 over 400+HP)
This HP Goal has no optimal revs. You have to run this which are required!
I talked to Peter Newman from Newman Cams some weeks ago. He recommended his 264° N/A Cam for Power till 9000rpm on Turbo engine. I think its not the best way to try everytime the biggest cam. Me and Acki talked a lot about the 272° N/A Cam from the X1/9 1.5L engine. You have tried this one?
At the moment i use for a good friends 1.9L engine this custom cam with the following facts:
272°
timing 35/67,
106 degree lobe centre,
10.3mm valve lift
What do you think about it Cry? Turbo is 28RS. HP Goal arround 300+
